SLP L/T application on bassani X
I'm thinking of ordering the ceramic coated SLP L/T headers from stage3motorsports, http://www.stage3motorsports.com/c=g...s__Coated.html and was just curious if anyone knows if these will fit onto the bassani X-pipe I have or will it need some fabrication? The add says its compatible with all factory emissions equipment but I'm not sure it will fit. Any thoughts or opinions will be appreciated, thanks. Oh ya if anyone has any suggestions on motor mounts I'd love to hear them, gonna swap out the k-member and figured might as well get some new mounts while I'm down there. Thanks again.
RE: SLP L/T application on bassani X
I didn't read the ad but if it did say it is compatible with all factory emissions equipment and the picture in the ad is accurate then they are wrong. Your factory cats will not fit into the stock location and would require some modification to get to fit. You would either need to run an off-road X or H-pipe or a catted X or H-pipe with those. If you went with a catted pipe, you still wouldn't be emissions legal since you relocated the cats to a non-factory location.
I feel flaming on the horizon.... |
