removing the antenna???
i never listen to my radio, can I just unscrew my ugly antenna with it having any problems? will there be an open hole for water and debris? i dont want a shorty antenna either...
RE: removing the antenna???
Yep, you will have 5 holes...
A big one and 4 little ones around it[8D].
No harm can be done if left open, just look like cr@p.
Where's Nelson (NELSGT), he made a plug for his.
I had it unscrewed for about a month because I never used the radio but didn't want to buy a short antenna. I had no problems while it was off. I put it back on because I ended up needing the radio for traffic reports. The radio still works fine
Yes you can just unscrew it with no problems. The holes they are talking about is if you remove the black mast piece. Then their will be holes under it. But since thats not what you want to do, just unscrew it.
