Fastlane twin turbo's are installed!!!!
RE: Fastlane twin turbo's are installed!!!!
ORIGINAL: mwilkes
it's 6999.00 (7K) which is a little more than the whipple setup. it's a little harder to install than the whipple butit makes the same power on less boost. My car on 9#s boost makes the same hp as a whipple at 13# and it actually makes about 50 more ft lbs torque. The other thing that's nice is it drives like it's stock if you aren't knee deep into the gas pedal. I actually had them do a custom install to add the blow of valve, but typically they vent it back into the unpressurized cold side of the turbo, which makes it really stealthy and quiet.
I'll do some action videos soon!
Now to your 13psi whipple making only 474rwhp. There are plenty making that on the 10psi pulley and 1 making over 500rwhp with full exhaust and 10psi pulley. I don't think you are any safer at 9.66psi than I am at 10.5psi, but if you do then that's all that matters. Actually with all the torque you are making, you're probably more likely to throw a rod.
Take it to the track and post some real numbers.
Twins do not make more power then singles.
Read Garrett's website about twins vs singles. Singles are preferred unless there is not room to mount a large turbo. Think about it, a small twin set-up doesnt spool any faster becauseonly 1/2 the exhaust gas is going to each turbine.
Regardless, that Fastlane set-up is very well thought out. I dig the turbo locations and routing. Congrats
ORIGINAL: CataclysmGT
I'd do this setup over the Hellion or any engine mount turbo any day.
Edit: Did you get a print out of the air/fuel? What kind of fuel system does the kit use?
i didn't get a print out of the fuel/air ratio. I'll get one for you thursday.
fuel system upgrades were ford racing 39# injectors and a kenne bell boost a pump and i think that's it
After all, they tend to be smaller.
