Sponsored by:
Sponsored by:
Calipers... Clear Coat.. wtfffffff ....
Old 02-07-2008, 10:48 PM
GTstangB.F.D.M.
GTstangB.F.D.M.'s Avatar
Default Calipers... Clear Coat.. wtfffffff ....
ok guys.. repainting my calipers from the duplicolor red kit to just 500 degree engine paint.. same exact paint that the caliper paint is, 500 degrees, ceramic, etc.. but this time im painting them to match.. and the match is like.. almost exact.. im suprised... but im sick of the red... too flashy for the car.. the dark grey will look awesome..
but i am doing spray this time instead of brush on.. and done about 5 coats, and then just sprayed a coat of clear of the 500 degree engine paint, and it went on like... white.. i was like..wtf... so im gunna go check it after i post this.. it will have been about 15 mins.. if it didnt dry clear, im just gunna paint a few coast over it, and then say screw the clear...
i will get pics up
GTstangB.F.D.M. is offline
Old 02-07-2008, 10:58 PM
SonicBlue05GT
SonicBlue05GT's Avatar
Default RE: Calipers... Clear Coat.. wtfffffff ....
clear just about always comes out a little cloudy. it should dry to be clear with a thin coat. too thick of coat and it can remain cloudy.
SonicBlue05GT is offline
Old 02-07-2008, 11:05 PM
PLstang
PLstang's Avatar
Post pics of the finished product!!
PLstang is offline
Old 02-07-2008, 11:22 PM
RHuckster
RHuckster's Avatar
I've found that cold damp days the clear will be cloudy & stays cloudy. I try to pick a clear warm day to paint.
Rick
RHuckster is offline
Old 02-08-2008, 12:11 AM
Burnsy
Burnsy's Avatar
you take the calipers off or are you spraying with them on? i have been wanting to do black but maybe I'll do this instead...
Burnsy is offline
Old 02-08-2008, 12:12 AM
GTstangB.F.D.M.
k, i decided to just forget using clear coat..hopefully this time it wont start chipping/peeling.. if it does.. whatever..ill do it again and takemy time with the clear..
looks sooo much better tho.. just waiting for the fronts to dry, and then throw the wheels back on and call it a night.. a long one.. look alot better tho..no so much flashy-ness IMO...
get pics up tomarrow
Old 02-08-2008, 12:16 AM
grabberorange1
grabberorange1's Avatar
I sprayed mine with the gray engine paint, and also cleared them and they look awesome...no problems with the clear coming out white.Test spray theclear onsomething else.
grabberorange1 is offline
Old 02-08-2008, 06:31 AM
GrayPony
GrayPony's Avatar
ORIGINAL: GTstangB.F.D.M.
G2 caliper paint.... doesn't chip/fall off like Duplicolor, lasts a long time and stands up to most mild wheel cleaners. It's also available in factory colors if you want to match your body color.
GrayPony is offline
Old 02-08-2008, 09:23 AM
gremlin190
gremlin190's Avatar
Clear Coat ??? On your calipers ???
That sounds kinda knarly
What about cleaning them? will you have to wax them too?
Can you do clear coat over vinyl?
Please post pics
gremlin190 is offline
Old 02-08-2008, 09:46 AM
ink003
ink003's Avatar
ORIGINAL: GrayPony
+1 G2 is an awesome product: hubcapsplus.com ftw
ink003 is offline
Quick Reply: Calipers... Clear Coat.. wtfffffff ....
