Mustang takes crap from light.....
Whats up fellas......
i just tohughtid post here with a question i have,,,,this is what happens,,,,
sometimes when im at a light, waiting for it to turn green (some lights in this town take forever), then when it finally turns green, i start to go....im not trying to punch it or anything, just driving regular, but as soon as i push the accelerator from a stop, it will go for a split second then it will act like the fuel pump or line takes a crap and pretty much dial down to nothing for a split second then it will be normal and act like nothing happened.......what is this ****?
RE: Mustang takes crap from light.....
You could have a recalled fuel pump
http://bradbarnett.net/mustangs/gala...hesonaccel.pdf
is that when you like turn the key on, push the gas all the way to the floor slowly, hold it for a sec, realease it slowly, then turn the key off?...or do i have it mixed up with something else?
This is a issue with a good number of Mustangs and there is a FordTSB on it.
Does it happen after you having been driving at highways speeds? That is a usual sign.
The Dealer should fix this with no problem. They did mine after I showed them the TSB.
There is a long thread on anothet stang site about this.
