Whipple Supercharger Dyno Sheets
Hi guys
If you had your Whipple S/Cdyno with the stock Whipple tune could you please post your dyno sheet(with the afr if possible)and what psi and if intercooled. This would be interesting to seenumbers on a stock Whipple tune running 8psi &10psiand wouldbe interesting to see what numbers you are getting vs others.
If your not sure how to post you could e-mail it to me and I will post it for you.
tjcj1993@sbcglobal.net
TIA
TIA
RE: Whipple Supersharger Dynos Sheets
all i have for posting is a pic of the
dyno monitor
i have the actual printout tho and the
numbers are:
MUSTANG DYNO
411 rwhp / 417 ft-lbs / FRPP tune / 91 oct / 10.8 AFR / 10.5 psi
[IMG]local://upfiles/37808/052015D784774E77BCAD8933070D10C0.jpg[/IMG]
[IMG]local://upfiles/37808/CA7552D117B443748B074F64D6FF2A72.jpg[/IMG]
dyno monitor
numbers are:
MUSTANG DYNO
http://www.m0dularfords.com/forums/s...no&page=27
Change the zero to an o. Sorry the link will get ***** if I leave it the way it is. copy and paste.
Go to page 24 to see the dyno run on only 1 pump. His A/F ratio was 18 or something crazy like that and the motor didn't pop.
He made 470rwhp and 450rwtq. he also has an O/R H I think.
ORIGINAL: hammeron
dyno monitor
numbers are:
dyno monitor
numbers are:
Very fat safe afr! even more power is there when your ready!
ORIGINAL: moosestang
Moose
Looks like they went very lean then evenhigher danger zone leannfor around 1300rpms with that afr and your right lucky it didn't pop. Yeah that was crazy I'd put them on mydo not recommend list for shops due to not shutting down sooner.
One time I was at a shop they were tuning on S/C car afr started hitting 14.9 and they were yelling shut it down.
Moose below regardingthe talk in the other thread on this subject (high & low dynos#)few thoughts and comments imo about that 470rwhp.
Ok I checked out that dyno thatafr looks nothing like the current afr we are seeing now on the Whipples today aleast what I have been seeing so far. That isleaner (but safe)in comparison to what we see now lookinglike 11.6+ to me in that graph. Thatwouldexplain agood part of the rwhp difference when comparing to the 10.8-10.9's we are seeing.
One thing to keep in mind alsothe dyno doesn't say corrected and if not incorrected the numbers would be a little lower than shown also maybe 460-465rwhp but still good high rwhp imo.
I also seen this posted by someone in that thread.
Mav,
Congrats on the numbers. What a beautiful air/fuel curve. After all of the talk of lean Whipple tunes, I'm relieved to see a success story.
Frank[/align]
Frank[/align]
Well I should be getting emailed my dyno sheets shortly but here were my numbers.
416rwhp 398rwtq with 8psi pulley, 11.5-11.8 A/F with 93 octane and Whipple Tune, SAE corrected 80 degree day.
Now for 2 comments
One is that I went over with my installer about dynos and he showed me different views of the same pull with different corrections. The ranged from a low of 412rwhp to a high of 436rwhp. This is just to show people that dyno's have alot of variation so they cant becompared apples to apples. They are just a tuning tool. The numbers are useless. Sorry that is a pet peeve of mine.
My second comment is on why I think the 10psi kits are running such a low A/F ratio.
During my dyno run my installer datalogged everything. He told me that if I ever wanted to up the boost I would need a MAFia. I was like WTF? Tons of people run this kit at 10 psi without one. So I asked him why.
He showed me the MAF reading the ECM was getting and it was in the high 970's. I think the MAF maxes out at 1032 or there abouts. He said that depending on the weather the MAF would be close to, or could be maxing out. My thought is if that is happening the ECM is saying "I have no clue how much air is coming in, so I will dump max fuel." This would lead to the overly rich condition.
Because I am running the 8psi pulley the computer can accurately read the amount of air coming in so it hold my A/F in the sweet range for Boost, 11.5-12.1.
Now I think that the whipple tune is doing the right thing dumping extra fuel as it makes it significantly safer, but I wonder how much better the ECM could do if people ran a MAFia.
I think people pick up extra with a dyno tune because the guy tuning it leans out the fuel when the MAF peaks out. Under most conditions this is fine but when it occurs your ECM is just guessing.
I have nothing substantial to back any of that up but from what I have seen and know about engine components that is what I infer happens.
Just throwing that out there.
Thanks guys and I must say it is great to be finely S/C. When I get a chance I will post another gloating thread with more info and pics.
Thanks
Now for 2 comments
Thanks
congrats guru and welcome to the crew
it's been a long time coming and you
finally made it to the big dance
i'd like to see the chart, so please post it here as
well as the new gloating thread
