Stupid gear question...
So. I'm trying to understand exactly how gears and driveshaft work soI can problem solve the whine I have (get into that later). Can anyone answer the following questions?
- Is the driveshaft rotating when car is moving and
a)in neutral?
b) in gear with foot off gas?
- is the ring and pinion rotating when car is moving and
a) in neutral?
b) in gear with foot off gas? (pretty sure answer is yes here, but asking anyway)
So, without going into my long rear-end/gear history, here is what my car does:
Whine/flutter type sound from back half of car:
- on decel/coast only
- fades in around 55mph, worse at 50, fades out about 40 mph
- goes away immediately on even slight throttle
- goes away if put car inneutral
- doesn'tgo away/changeif turn overdrive off
I'm trying to decide if this is gears, cause if it is i'll just upgrade and e done with it. But I will be p*ssed if I do that and the whine is still there. i'm also a littel concerned that it's the tranny, although my gut tells me otherwise.
TIA
a)in neutral?
a) in neutral?
TIA
RE: Stupid gear question...
Okay, thanks.
So, by the same token, couldn't the whine be the driveshaft or tranny since they work on the same load principle? i doubt it's tranny since it doesn't change with rpm at same speed (turn off OD), but how 'bout drive shaft or even u-joints?
Im my experience, if it's whine, it's gears. Driveshafts will vibrate if there is an issue and u-joints will clunk if they're bad.
Still trying to figure out what goes chitty chitty bang bang
If this is the stock rear two-piece driveshaft in a GT it could be the driveshaft carrier bearing.
However this normally whines on throttle I believe.
The number one suspect is the ring and pinion in my opinion.
KingRando
10-02-2015 08:06 AM
junior04
09-28-2015 10:53 AM
