My half ass job / some questions.
My half *** job / some questions.
Okay, so i completely re-edited this thread, so ignore the first few posts
Anyway... i got the bbk intake used, and it had no instructions, the guy who i bought it from did it without the heat protector, so i wanted to use it. Me and a friend went to put it in and we couldnt figure the damn thing out! We got pissed, so we tried bending it and trying to fit it in. Finally, i posted a thread about it and found out we had to remove the radiator cover.. so i did it about 5 mins ago, and since the heat protector was all bend up and stuff, i didnt know where to line it up, so i just bend it some more, and put it wherever it fit.. heres some pics.
Heres my question, what is this thing? Does it get hot? The heat protector is touching it...
RE: removing radiator cover
ORIGINAL: whtcanbrwnd04u
Wait.. after i pry'd up the center part, do i hold the center part and just pull? I dont want to break any, so better safe then sorry.
OK, leave the center part up, then get the rest of the anchor out of the hole. The center part just goes down and expands the other part so it will hold sort of like a wedge.
Gotcha! Thanks.. another question for the BBK INTAKE guys. Where do you install the heat protector after removing the radiator cover? (i dont have the instructions)
Im guessing its one of the things i circled, which color one?!
ORIGINAL: tungsten07
if you line it up it should fall over what bolts you have to remove to get it to fit and then just re-bolt it
