Question
Question
hey, i have an 08 v6 stang (auto) and i have a friend who told me that i can **** the gears starting in 1 rev the engine then put it in 2 then 3 then drive, is this bad for my car since i have an auto and there is no manumatic shifting?
RE: Question
It can be bad if you're doing this all while not moving (as in trying to burn out, etc.), but if you're just starting in 1 then going a ways then shifting to 2 driving a ways then shifting to 3...then shifting to Drive it's not bad for your gears. Those are there to cause the engine to turn at a slower rate. 1 being the lowest D being normal. All you're doing is causing the car to shift earlier (or later) than the computer would.
RE: Question
To more clear puttung the car in N then reving it up then slaming into any gear is very bad! When I was in high school a buddy use my car this way and broke the motor mount, u-joint, and transmission mount.
I repeat do not slam it into gear from N!
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
