Recall RCM 08C02 / Tune question
So has anyone with a tune had the recall work done yet? I'm getting mine done Saturday and would like yto know if I can put my Bamachips tune back on once everythings done or if I have to get an updated version of my tune
RE: Recall RCM 08C02 / Tune question
+1
everyone seems to bash someone for asking the same ? again, but I havent seen the answer..
If I return to stock, and then they fix the problem, will putting the tune on again just undo the thing that they fix when I bring it in?
..brenspeed is away until march 4 for a thing in FL, so I can't ask them..
From what I've read they don't touch the PCM (Powertrain Control Module), they only touch the RCM (Restraint Control Module).
You shouldn't even have to return to stock.
ORIGINAL: sailing220
ORIGINAL: 2cokeman
My dealer told me they are updating both??
[align=left]SERVICE ACTION[/align][align=left]Dealers are to reprogram the Restraint Control Module using IDS (Integrated Diagnostic System) that[/align][align=left]is updated with release (R53.7) P16 or later. This service must be performed on affected vehicles at no charge to the vehicle owner[/align][align=left][/align][align=left]As far as de-tuning the car it is not nessicary i did mine myself today and just decided to return it to stock re-program the rcm then re-install my brenspeed tune but it is not nessicary since there not re-programing the PCM. [/align]
I've also heard that they're not impacting the PCM, only the RCM.
If you want, you can return to stock, then uswe your tuner to obtain the "Strategy" and jot it down. After you return from the dealer, use your tuner to verify the strategy hasn't changed then reload your tune. If it HAS changed, you need your tune supplier send you new revised tunes.
