New Wheels= 12MPG
RE: New Wheels= 12MPG
Not to mention erroneous readings on the overall odometer. Youre basically commiting odometer fraud one way or another.
Recalibrate it. Now.
Also, the heavier 20" rims, which could be what, 8lbs heavier each corner of unsprung weight, times 4 corners, times 6 to convert to sprung weight, you're basically carrying 190-200lbs extra on the car after the conversion.
At least they look cool......... they do look cool, right?
ORIGINAL: laserred02
Is this the mileage from the trip computer or hand calculated? As others have noted if you have not updated the computer to compensate for the diameter change your speedo and other things will be off contributing to erroneous MPG calculations by your computer.
My speedometer is off by 2-3mph at 70, but at 50 or below it seems right on.
How are you computing this MPG reading?
The OE trip computer or good ol math?
Whats the revs per mile of the tires removed
and the tires installed? Did you factor the difference
between the two.
between the two.
Mpg is calculated with the front wheels and not the back wheels, if you entered your rear wheel measurement then it will cause the errors
Thereforewhen you change the revs per mile you would base it on the rear tire size.
ORIGINAL: zkiller
That seems odd because the rear wheels are connected to the driveshaft, which is connected to the transmission which I believe has your speed sensors.Since the drivetrain all runs off the back wheels where how do the front wheels come in to play?
