vibration in car or wheel hop??
last nite i was getting on my car out of the hole and it felt like a vibration from the rear end or is it wheel hop? is that normal? what can i do to fix it? i have no performance mods but gta's axlebacks!!
RE: vibration in car or wheel hop??
You are hoppin.
I replaced my OE rear springs and shocks for Roush and it minimized
the wheel hop. I also went from 215mm wide tires to 235mm wide tires.
The next step would be LCAs and a new UCA with
stiffer bushings instead of the soft OE rubber ones.
[IMG]local://upfiles/69445/8AB1DC85DCB248A691261A723EE45290.jpg[/IMG]
You need upper and lower control arms to eliminate wheel hop. I don't understand why people recommend a sticky tire. Wheel hop is a direct result of your suspension flexing causing the tires to leave the ground or hop. In our case it's the control arm bushings that are mostly responsible. Wheel hop sucks and looks stupid if you are outside the car.
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
