Vented Hoods?
I see all these aftermarket hoods on the maket now with vents and intake piping, even the GT500 has vents don't have gutters at all. Where does the water go?? I know the shaker hoods have some kid of gutter system, but like the KR hood they use on K.I.T.T. for example, you are running hot and a heavy rain sets in, cool water crashing on a hot engine sure would seem healthy to me. Which brings me to the question of, where CAN'T water hit on an engine? i mean hell if it can rain on my motor i can probably use a hose to clean it, but there has to be limits, no?
RE: Vented Hoods?
The only spot you don't want water pooling is in the coil packs. They become hot and crack, which causes misfires. I wash my engine and bay regularly, but I use high pressure air to blow out the water after, and have no issues. In order to get water ingestion frm the hoods, you would need a firehose spraying in constantly.
RE: Vented Hoods?
See but for example, the hood below pulls air right to the intake, but i would imagine while raining, water would flow pretty easily in there while driving, which would pretty much cause it to dump right on the intake. Just an observation.
http://i248.photobucket.com/albums/g.../05gtrhood.jpg Credits: This image was taken from mrbodykit.com i have used it without permission but am using it in the interest for purchasing this hood, and in no way trying to use it for profit. |
RE: Vented Hoods?
Just be careful not to drench the engine. Ive driven in wicked rain before but I make sure I dont park it under the rain. And I avoid running water on the vents into the engine when washing.
RE: Vented Hoods?
I wonder how much of a possibility it would be to make some kind of detachable inner cover for the vents. The intake would pull from the normal place when the scoop is blocked off. I think the real task would be actually making it look good when the hood is popped:). Maybe plexiglass or something. All i know is i have to ditch the stock hood on this one. That goofy bolt on scoop it came with is making my stomache churn.
RE: Vented Hoods?
The way mine are is they have drain vents on the bottom. But I have a heat extractor not a ram air. I would think though even in heavy rain the water would be mist by then.
RE: Vented Hoods?
ORIGINAL: T See but for example, the hood below pulls air right to the intake, but i would imagine while raining, water would flow pretty easily in there while driving, which would pretty much cause it to dump right on the intake. Just an observation. http://i248.photobucket.com/albums/g.../05gtrhood.jpg Credits: This image was taken from mrbodykit.com i have used it without permission but am using it in the interest for purchasing this hood, and in no way trying to use it for profit. |
RE: Vented Hoods?
I have sorta had the same problem as you. I am not looking to right now but in the future I am looking to get a hood. The ram air hoods that are just ram air I dont think you would have much of a problem with. The few turns and little rain to begin with that is going into the vents I dont beileve would be a problem. On the other hand, if you were going to get a GTS type hood (like I want) they have the heat vents to. This does bother me because driving you wouldnt get that much water in there unless it is a complete downpour but what happens when the car is setting. How do you keep the water out of the engine compartment. That is my 2 cents so basically I have the same question as you
RE: Vented Hoods?
ORIGINAL: PROMETHEUS PRIME The way mine are is they have drain vents on the bottom. But I have a heat extractor not a ram air. I would think though even in heavy rain the water would be mist by then. |
RE: Vented Hoods?
I only drive on nice days so hopefully the rain will not be a problem...My hood did come with removable trays for the top vents.
[IMG]local://upfiles/31319/D2845E073C4149CE84BD6EBA96122062.jpg[/IMG] |
