s197 W/ 110,000 Miles - What Will Break?
RE: s197 W/ 110,000 Miles - What Will Break?
Lucky you. I have 24k miles and already had the whole differential and driveshaft replaced, broken lumbar support, strut mounts replaced, squeaking steering wheel, creakingcontrol-arm bushing, and have just discovered that I have the infamous passenger-side water leak. Somehow though, I still love this freaking car.
ORIGINAL: richmod
Why not get a new mustang and give those problems to some one else? This isn't a 2nd world country where the economy does not work in your favor...
ORIGINAL: wasvette
richmod - sorry to hear that - I've had a few cars with issues no one else had...
ORIGINAL: richmod
ORIGINAL: Legion5
Well here is what Ford suggests: (No indication of the clutch/tranny at least in this window of milage)
100,000 Miles
Change Premium Gold engine coolant
Change engine oil and replace oil filter (up to 5 quarts of oil)
Inspect accessory drive belt(s)
Perform multi-point inspection
Replace PCV valve
Replace spark plugs
Rotate and inspect tires; check wheel end play and turning noise
105,000 Miles
Inspect and lubricate all non-sealed steering linkage,ball joints,suspension joints,half and drive-shafts and u-joints
Inspect brake pads/shoes/rotors/drums, brake lines and hoses, and parking brake system
Inspect engine cooling system and hoses
Replace cabin air filter
110,000 Miles
115,000 Miles
120,000 Miles
Inspect complete exhaust system and heat shields
Replace engine air filter
Replace fuel filter
125,000 Miles
100,000 Miles
Replace PCV valve
Replace spark plugs
105,000 Miles
110,000 Miles
115,000 Miles
120,000 Miles
Replace fuel filter
125,000 Miles
ORIGINAL: pascal
I just realized...
If you haven't changed your belt by now, it's over due[8D].
I think the manual says to do so at 60K miles.
I just realized...
ORIGINAL: red07Pony
100,000 Miles
Replace PCV valve
Replace spark plugs
105,000 Miles
110,000 Miles
115,000 Miles
120,000 Miles
Replace fuel filter
125,000 Miles
100,000 Miles
Replace PCV valve
Replace spark plugs
105,000 Miles
110,000 Miles
115,000 Miles
120,000 Miles
Replace fuel filter
125,000 Miles
Still need to do brakes, pcv, plugs and she'll be good for another 100k All kidding aside, I sell over the road so this car will be over 150,000 miles or more by Christmas. She's destined for a Ford advertisement.[8D]
