Will this be bad IF....
.... I have Steeda Springs (about 1" drop), and Tokico D-specs installed, and DO NOT install an Adjustable Panhard Bar/Brace, and Camber adjustments at the same time? I would be running the car like that for about a month or so, until I get some funds to install the rest. I do not want to wait to install the springs & dampers for personal reasons lol :)
RE: Will this be bad IF....
ORIGINAL: VerginaStang .... I have Steeda Springs (about 1" drop), and Tokico D-specs installed, and DO NOT install an Adjustable Panhard Bar/Brace, and Camber adjustments at the same time? I would be running the car like that for about a month or so, until I get some funds to install the rest. I do not want to wait to install the springs & dampers for personal reasons lol :) |
Kinda depends on how much you're going to drive the car in that month. You probably won't notice much difference in the driving, it MAY pull to one side, but the biggest issue will be the amount of tire wear you'll incur in that month. When tires start to show wear from mis-alignment, it's AMAZING how much damage that can cause in a short amount of time!
De Ja Vue
Search function. La La La... Ahh, here it is.... https://mustangforums.com/m_4742968/tm.htm Its OK to drive but the toe will be crazy out. Or forgo all the front end alignment and geometery problems with Dropped Spindles. :D [IMG]local://upfiles/69445/32CB1C68DA8C4E17919AD23412B50C07.jpg[/IMG] |
I installed Eibach-Pro, D-Specs and J&M Camber plates about 2500 miles ago. Have not had it aligned. I set the camber plates to the most positive camber position they would go (strut top nuts towards the outside of car). No adjustable PHB yet. My drop is ~1.4"
Last weekend I pulled the wheels off (putting my summer wheels on) and observed the fronts were very slightly scrubbed on the outside.At first thiswas unexpected, I thought they might be scrubbed on the inside. But in retrospect its probably because I have the camber plates set to the positive camber side or it could also be due to agressive driving...so nothing definitive. But my point is: 2500 miles with really very minimal wear.With lots of miles you *may* start scrubbing the inside of your fronts. Just drive and check them every 500 miles or so. Other than that you won't have problems. Your rear end may be slightly off center but, unless you have really wide rear tires, its hard to even notice and won't cause you any problems. |
You could drive the car forever without any other suspension parts and you'd be just fine. A 1" drop doesn't affect things much at all....except looks :D
You will be fine...I have the Eibach sport kit and no camber plates. I did have the adjustable PH installed but didn't need toadjust itat all.
i dropped my t/a about 1.25" and lost all traction[&:]
A 1" drop doesn't affect things much at all....except looks |
vin, the one inch drop isn't that agressive. I would get the adj. panhard rod to be safe but it wont be too far off.
