Pinion depth and backlash
Im going to install 3.73 ring and pinion but there is information i need that i couldnt manage to find. The pinion depth andits backlash. What are they?
The shop guy asked for them and i need them asap. Also it would be great if any1 can give me a link to a how to do guide for installing 3.73 gears. Thanks |
RE: Pinion depth and backlash
Heaven help you..I know it is probably hard to find qualified techs that work on stangs but you are really rolling the dice with this install.
ORIGINAL: UAE_Muscle Im going to install 3.73 ring and pinion but there is information i need that i couldnt manage to find. The pinion depth andits backlash. What are they? The shop guy asked for them and i need them asap. Also it would be great if any1 can give me a link to a how to do guide for installing 3.73 gears. Thanks Here is an article that should help you http://www.corral.net/index.php?opti...&Itemid=26 |
I did my own gears having never don it before & had perfect results using the article below. I assumes that you have a good setup from the factory to begin with & you are using Ford gears for the rebould. Basically you measure your old pinion head thickness then measure the shim behind it, add them together, measure your new pinion head thickness then subtract from your total reached before and you have your shim thickness that should give you the proper depth. Anyway read the article & it works, I have the quietest 3.73's in town.
http://www.superstallions.com/tech/d...ars/gears.html |
