HELP!!! MGW Shifter bolt broke off!!! Gotta be fixed by Mon morning
RE: HELP!!! MGW Shifter bolt broke off!!! Gotta be fixed by Mon morning
ORIGINAL: vphokie
How can the dealer not be able to order just that part? WTF? It's not like the assemblyline on our models has stopped making parts... [:@]
Good luck getting that fixed bro!
this blows- i, like you Gman, have to spend 300 dollars on a stock shifter. after i spent 300 on a MGW. no one around here has a junked s197....
2 weeks after the install i jacked the car up and was changing oil - decided to make sure everything was still tight down there. the bolt that i snaped off isn't even really part of the install for any shifter - the black bar connects to the base of the shifter and that connects to the transmission. too many beers i guess.
IF ANY ONE KNOWS OF A POOR SOUL WHO HAS TOTALED THEIR MANUAL V6, LEMME KNOW.
so one the other side of that black piece it a bolt that is welded to it somehow?then it slides through and the nut goes on it?
why couldnt you just remove it,cut the old bolt off,drill a hole through the black piece and use a real bolt to all the way through?
