Aluminum DS?
RE: Aluminum DS?
Make sure to get an adj. upper control arm if you are lowered and I know Coast says reset the pinion angle to 0 degrees. I have the Eibach pro kit and had the fixed upper control arm and am getting a vibration at about 85 mph. Contacted Coast and they say it is a MUST to change the pinion angle. It will save you a big time hassle and worry.
RE: Aluminum DS?
ORIGINAL: DeStonn
RE: Aluminum DS?
ORIGINAL: JRT1
I have adjustable LCAs, same thing right?
ORIGINAL: DeStonn
RE: Aluminum DS?
ORIGINAL: DeStonn
No, get the adj. upper to change the pinion angle
ORIGINAL: JRT1
ORIGINAL: DeStonn
RE: Aluminum DS?
I know LCAs aren't the same as an UCA, LOL.
What I ment was adj LCAs can adjust the pinion angle to so a adj UCA should not be needed.
DeStonn you don't agree with that?
Who agrees or disagree with this and why?
Thanks.
Thanks.
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
wishinsky
09-21-2015 09:48 AM
09-16-2015 07:53 PM
