Sponsored by:
Sponsored by:
4.10s or driveshaft ??
Old 03-22-2008, 04:07 PM
lowrider954
lowrider954's Avatar
Default 4.10s or driveshaft ??
I have an 06 gt...next mod 4.10s or aluminum driveshaft? current mods; c&l racer,sct,steeda udp & cmcv plates o/r xpipe, magna packs...
lowrider954 is offline
Old 03-22-2008, 04:16 PM
smythge
smythge's Avatar
Default RE: 4.10s or driveshaft ??
4.10s
smythge is offline
Old 03-22-2008, 04:29 PM
nofear
nofear's Avatar
I think it depends on what u are using the car for
if you are taking it to the track and not as a daily driver than 4.10s
but 4.10s will hurt your gas millage and you will be shifting sooner i may be wrong
an aluminum drive shaft will have less rotational enertia since it weights probably 20 pounds less, it will free up some horses
i think you should start with the shaft first
something to think about
nofear is offline
Old 03-22-2008, 04:45 PM
dferkler
dferkler's Avatar
both
dferkler is offline
Old 03-22-2008, 04:47 PM
157dB
Cut & Paste Expert
157dB's Avatar
4.10s will give youa better dollar to gratification smile.
157dB is offline
Boozshey
Boozshey's Avatar
4.10's no hesitation...
Boozshey is offline
Old 03-22-2008, 05:18 PM
howarmat
s197 Junkie
howarmat's Avatar
both......you probably gain some MPG with the DS, you might lose some with the gears...break even!
howarmat is offline
Old 03-22-2008, 05:26 PM
Stkjock
Retired Mod
Stkjock's Avatar
ORIGINAL: howarmat
+1
if $$ is a factor 4.10s first then DS
the 4.10 actually make 5th gear work!
Stkjock is offline
Old 03-22-2008, 05:44 PM
lowrider954
ok..cool guys thanks..the only thing holding me back on the 4.10's is....... is there a traction issue since acceleration is so much harder...will hooking up be harder..is basiclly my main question..
Old 03-22-2008, 05:54 PM
tripc
tripc's Avatar
Just got my 4.10 taken out and put my 3.55 back in.. I hated the way it drove around town with the 4.10.. But everybodys diff
tripc is offline
Quick Reply: 4.10s or driveshaft ??
