FRPP "Hot Rod" Cams are out!?
RE: FRPP "Hot Rod" Cams are out!?
ORIGINAL: white07
so this isnt really them?
http://www.youtube.com/watch?v=E1mYzsxMbo4
and since they are frpp does that mean they will be in the ford catalog? If so someones getting a discount!
ORIGINAL: DarkFireGT
According to someone inside Ford Racing, they are not. I doubt the idle will be that wild. It will be rougher than stock, no doubt. But anything that idles like that is going to require springs.
ORIGINAL: white07
I was gonna say, thats a pretty rough idle lol!
but I wasn't sure if if they were in fact the FRPP, so I did not
ORIGINAL: eddieval5
Found this on Sutton High performance and my question is are these really out and are they worth it for an N/A motor right now? Ive been saving up a little here and there and by June i should have a Whipple or Vortech S-trim.
http://www.suttonhp.com/store/item.a...ARTMENT_ID=253
These cams look like valve float waiting to happen. The lift numbers are sort of aggressive for a no spring cam. Personally I'd look intothe Comp CamsVSR series (#127100/300) cams so the valves can open a resonable amount andremain undercontrol of the springs and lifters. Comp also has some more conventional looking higher lift cams that are milder with lots of midrange and top-end but you have to do the springs and install their VCT cam phase limiters which is what allows them to run that extra 0.07-0.08" lift which makes these things hit so much harder than even their Stage 3 cams. Even the mildest of theirSPR series (#127400)cams will produce 45-50rwhp on a full bolt-on car and have a perfectly docile idle, nobody will even know you have those cams in the engine until you blow past them. GOK what you can get out of the #127500 and #127600 cams though some have reported getting 60-70rwhp with carefully ported heads and needless to say all the bolt-ons, injectors and custom tune.
HTH!
EDITED for a typo
