Wideband wiring help
Hello,
Im trying to install a wideband on a 06 mustang GT, and need a power source which is only active when the ignition switch is opened. Anyone know where i can tap into one? So far its direct so it stays on always.
thanks
thanks
RE: Wideband wiring help
Just use a miniadd-a-fuse in the fuse box in the kick panel. There are like three un-used fuses in the box that you can use. There are two ignition-on fuse slots. I am using those for my gauges (5)
jwog666
12-27-2021 08:09 PM
Matt's 95 Stang
10-05-2015 07:16 AM
