Pioneer Avic Z2 Help !!
Old 03-29-2008, 08:59 AM
ThumperMX113
Default RE: Pioneer Avic Z2 Help !!
Alright, I drove it around for a little while and it picked up where I was at except it's pretty sketchy. It's not smooth at all so I'm suspecting that I need to move my GPS Antenna. Where did you guys mount yours? I really don't want it on the outside. I'm thinking about putting it in the headliner above the driver's head basically.
Did you guys hook up the VSS as well? I've got the wires in the center console kick panel so it won't be much of anything to run it up to the front PCM. But I'm still not positive where it hooks up. I know it's PIN3 on the top PCM Block but I'm still a little confused. I guess I'll need to look at it a little more.
ThumperMX113 is offline
Old 03-29-2008, 09:25 AM
GuitarGuyBMG
I installed my Z2 with the help of some friends along with my tint protector. It was an all-night process but it was fun and we got it right I do believe. For me the system automatically locked on to my location. The VSS wire is the blue wire with small yellow stripes on it. If your looking at the front of your car it will be on the left-front (on the side of your right-front tire) to the left of your engine assuming you are standing infront of it. Just splice into the blue/yellow wire and viola. Your done.
GuitarGuyBMG is offline
Old 03-29-2008, 10:13 AM
luvrbcs
Also, the VSS wire is in the top bundle of wires coming out of the PCM. If you disconnect the upper connector it will be a lot easier to work on. I fed the wire through the firewall by poking it through the same grommet used for the car antenna. The antenna wire is orange so it was easy to find.
I placed my antenna on the rear shelf. It is small and by placing it just beyond the seats, it isn't showing much wire.
luvrbcs is offline
Old 03-29-2008, 10:19 AM
howarmat
s197 Junkie
howarmat's Avatar
Yes you need the VSS wire IMO. And i am sure your GPS ant is fine where its at......the nav will get better the more you drive around i assure you.
Avic411 is a good site, you really should utilize it, there is a wealth of info on these units, just the same as there is a wealth of info for the s197 mustang here.
howarmat is offline
Old 03-29-2008, 03:01 PM
ThumperMX113
I think I'm going to throw it into my headliner with a piece of metal for the base. I've got it on top of the unit temporarily so I'm sure it's causing a ton of electronic noise. During a whole drive it moved onto the road that I was traveling on twice and I've only got 3 sat. images for the signal strength so I think that's my problem.
Old 03-29-2008, 03:09 PM
howarmat
s197 Junkie
howarmat's Avatar
yeah i put mine against the fender on the passenger side under the dash....works perfectly 5+ sats normally
howarmat is offline
Old 03-29-2008, 03:15 PM
ThumperMX113
Well thanks for the help man, I really appreciate it. I'll let you guys know what happens when I move the antenna.
Old 03-30-2008, 07:20 PM
ThumperMX113
I got it working yesterday. I drove around a little bit more and it started getting better. I moved the antenna to inside the headliner with a piece of metal, it got even better. I'm getting a pretty consistant signal strength of 6-7. I'm so pleased with this unit. I was so close to going with the Eclipse like I had in my trucks, but I don't regret it at all !!
jrrhd73must
10-02-2015 09:17 PM
04OrangeGT
02-22-2005 01:37 PM
Evil Sephiroth
11-04-2004 08:19 PM
Fallstar01
09-30-2004 04:31 PM
Quick Reply: Pioneer Avic Z2 Help !!
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
