Pioneer Avic Z2 Help !!
I ordered my Z2 from SonicElectronix.com, got it yesterday and everything was perfect. They got the right wiring harness and dash kit. I had purchased everything I needed to get the installation done from Radio Shack including the voltage regulator, etc. I got it installed tonight. I soldered all of the connections, etc. I was pretty happy with the outcome.
The dash is still apart and I turn it on. The Bypass works flawlessly except the navigation doesn't. It's showing that I'm in California when I live in Florida. The arrow isn't even moving. The GPS Signal is showing a strength of "Okay" so it should be picking up something. Do I need to set something up in the menus before it'll read? I reset it in the beginning and I drove around for a couple minutes but I still can't get it to work. What do I do? :( |
RE: Pioneer Avic Z2 Help !!
keep driving......i think it will lock on after a little while.....its been a long time since i installed mine but i remember starting out in LA also
How long does it take? I forgot to mention my antenna doesn't fit either.
drive for 10-20 minutes
So I don't need to set-up anything in the beginning?
without looking at a manual i dont think so, but you have a manual right?;)
Yup, but the manual doesn't even tell you that. It doesn't say anything about setting it up nor about having to drive for a little bit.
well take it for a drive and then come back and tell us what happened then!
Have you tried www.avic411.com most of your questions can be answered there I found a lot of good help when installing mine.
[IMG]local://upfiles/67105/1E44655AA7534575A7E78150750D5835.jpg[/IMG] |
Nope not really, just a lot of smart asses.
