SLP Line Lock Video Works!
#22
Where did you find the switch guard? Does the guard fit over the plastic paddle switch that comes with the kit or did you replace it with a standard toggle switch then install the guard?
Reason I ask is I want to install the switch in the same location you have, only problem is the fear of inadvertent switch actution, hence the desire to find a switch guard.
Appreciate the help!!!
JT
JT
Sactown put his behind the left turn signal. I choose that particular spot because I already had a hole drilled there where i had my N2O switch a few eyars back. The E brak does not affect the use of or operation. I've used the switch more time than I can count and have never had a problem.
#23
