MustangForums.com
MustangForums.com (https://mustangforums.com/forum/index.php)
-   2005-2014 Mustangs (https://mustangforums.com/forum/2005-2014-mustangs-43/)
-   -   Help me decide on UCA and LCA's (https://mustangforums.com/forum/2005-2014-mustangs/427265-help-me-decide-on-uca-and-lcas.html)
StangAddiction Apr 1, 2008 12:38 AM
I was planning on getting BMR UCA, LCA's, and panhard bar. After checking into the CHE brand, they seem to be great also. However, CHE offers the LCA's with the "bracket" for the brake lines and also, they havethe Delrin bushing added for less maintenance and squeek free. The only hold back for me is that CHE doesn't offer a panhard bar with center adjustment, only adjustment on the end. I read that center adjustment is better. BMR has the panhard bar with center adjustment. I wanted to get all the pieces from the same manufacturer. Would it hurt to get the control arms from CHE and the panhard bar from BMR? Thoughts??
Thanks.
sevenleaf Apr 1, 2008 08:17 AM
RE: Help me decide on UCA and LCA's
I went all BMR and haven't thought twice about it.
PiggySmallz Apr 1, 2008 08:48 AM
+1 I'm all BMR, its a great suspension
mac10chap Apr 1, 2008 09:08 AM
no thread stealing here...just a more in depth question about the LCA's
Do you have to get the LCA lowering bracket with the LCA's?What are its advantages as opposed to just mounting the LCA's directly into the stock bolt hole? Also, are the billet or adjustables worth the extra $100+ on a daily driver or will the cheaper poly's be sufficient
PiggySmallz Apr 1, 2008 09:31 AM
ORIGINAL: mac10chap
if the car is lowered more than an inch then LCA relocation brackets are strongly recommended to adjust the angle of the lower control arm. When the car is lowered with them in the stock location they are angled in a way that would enhance wheel hop and not stop it. With the relocation brackets, the angle of the control arms is fixed and is more parallel to the ground helping prevent wheel hop. As far as adjustables go, you do not need them. It is easier to go with an adjustable upper control arm, because it's one piece where as the lowere control arms are two pieces. It's easier to adjust one piece than two ;). The reason for having adjustable control arms is to be able to adjust pinion angle. The pinion angle changes when the car is lowered and you also want adjustability if you decide to go with a one piece driveshaft. Poly bushings are more than enough for a daily driver also, just be sure to grease them every oil change.
rad_rob Apr 1, 2008 10:23 AM
You should check out the Currie control arms. I just put them on this weekend and I love them. They have the Johnny Joints in the ends which are reaally nice and if they ever need to be rebuilt, you can do so for cheap. The Johnny Joint is somewhat like a heim joint, but they are rebuildable, and the ball center rides on 2 polyurethane bushings. Theyre offered in billet aluminum lowers and also in tubular steel. Theres also an upper adjustable UCA that has the Johnny Joint in it as well. You should definitely check them out.
mac10chap Apr 1, 2008 11:25 AM
ORIGINAL: xROBxCOREx
Is this just b/c you work for them or are they really a decent product?
PiggySmallz,
Thank you, you answered all my questions about them. I have the Eibach pro kit which is lower than a 1" drop. I just ordered Tokico D-spec Shocks and struts. I am about to order the BMR tubular LCA's with the relocation brackets. Thanks again...
rad_rob Apr 1, 2008 11:55 AM
Of course its going to seem like Im just saying that because I work for them, but thats not the case. Ive sold hundreds of these sets already, and havent heard any complaints yet. Ive been real happy with them.
http://i82.photobucket.com/albums/j2...5/DSC_0168.jpg
http://i82.photobucket.com/albums/j2...5/DSC_0188.jpg
Youll see there are quite a few other companies who have copied our joints as well. Theres a reason they do. lol
sevenleaf Apr 1, 2008 12:00 PM
I'd probably advertise for the company I work for too since they do pay the bills.
TOMBSTANG Apr 1, 2008 12:13 PM
I have never even heared of anybody running these or selling these and they look similar to the stock lca. The BMr look like they are on steroids compared to those[8D]
© 2026 MH Sub I, LLC dba Internet Brands
