Sponsored by:
Sponsored by:
How do you double clutch?
Old 04-01-2008, 03:14 PM
luckydawg003
luckydawg003's Avatar
Default How do you double clutch?
Just a ?, what exactly is double clutching. I tried it today to see if it would make my shifts smoother, it kinda did. First I tried it were I shifted from first to second gear, and I pushed the clutch in, put it in neutral, then released the clutch, then pushed clutch in again and put it in 2nd gear....Then I tried just holding the clutch in putting it in neutral, then whatever gear I was upshifting into, it seemed smoother, than the normally jerky shifts I get usually. Any ideas?
luckydawg003 is offline
Old 04-01-2008, 03:15 PM
Spiffu
Spiffu's Avatar
Default RE: How do you double clutch?
Ask vin diesel.
Seriously, I've always been told it's for cars with gear boxes that don't have syncromeshes.
Spiffu is offline
Old 04-01-2008, 03:18 PM
Joolander
Lord High Protector
Joolander's Avatar
ORIGINAL: luckydawg003
thats basically what you do, and Spiffu is right, at least thats what I heard
Joolander is offline
Old 04-01-2008, 03:24 PM
rad_rob
rad_rob's Avatar
Yeah, its for cars without synchros. Being that ours have synchros, theres no need.
rad_rob is offline
Old 04-01-2008, 03:28 PM
Norm Peterson
Norm Peterson's Avatar
Beg to disagree at least a little (I know, we've been through this one before).
It does make life a little easier on the synchros under certain situations.
But the OE drive-by-wire is not the sharpest tack in the box when it comes to working with you on this. Sometimes the little kick on the gas as you re-engage the clutch in the neutral gate gets you . . . nothing. Fortunately, tunes seem to be a bit smarter (at least the FRPP one is).
Norm
Norm Peterson is offline
Old 04-01-2008, 03:59 PM
157dB
Cut & Paste Expert
157dB's Avatar
It keeps your RPMs up between shifts?
Its actuallybumping the gas inbetween shifts?
157dB is offline
Old 04-01-2008, 04:03 PM
chain1
chain1's Avatar
Double clutching is really only useful in these cars when downshifting.
chain1 is offline
Old 04-01-2008, 04:10 PM
GNISROH
GNISROH's Avatar
Double clutching is where you
1 - push in the clutch for a downshift
2 - shift out of gear
3 - let the clutch out
4 - blip the gas
5 - depress the clutch
6 - shift into new gear
7 - let clutch out
You need to do all of this within 1/2 a second or so for the RPMs to stay up where you need it them to be. Those that have said double clutching is for gearboxes with out synchros are right. However, this is a good technique if you don't want to upset the weight distribution of the car during a turn. This is basically what Heel-Toe driving is, except you're operating the brake while you're blipping the gas.
Linky for different shifting techniques (including some exercises)
HTH,
GNISROH
GNISROH is offline
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
Thunderball
15
11-22-2015 11:49 PM
junior04
09-28-2015 10:53 AM
MacSerio
09-27-2015 01:05 PM
ccdguy
09-19-2015 05:20 PM
Quick Reply: How do you double clutch?
