hey guys.. got in a debate at work.. do we have posi trac or an open rear end?
Well, TECHNICALLY (and this is being REALLY, REALLY nitpicky) GM coined the phrase "PosiTraction" to describe the LSD rear ends in theChevrolet line when it first came out, so, no, we don't have "PosiTraction". The Ford Version was called "Equa-Lock" or "Trac-Lok" depending on the vehicle.
However, to answer your question, yes, most GTs should have an LSD in the rear end.
GT's come stock with a limited slip. So when you see both tires spinning, thats with a limited slip. If youre getting confused by "posi" and "limited slip", they are the exact same thing, just different terms. When they are doing a brake stand, both tires are spinng too...
