Pypes off road H pipe question 05-08Mustang
The message belowwas sent now twice to Pypes Inc with no response. Has anyone out there had a simialar problem with this OR/H pipe for the 05-08 Mustang GTand what have you done to fix the leak?
I bought an Pypes off road h-pipe and I can not get the passenger side portion where it meets the factory exhaust manifold to stop leaking. I
have tried everything to get it stop leaking and it still leaks. I have come to the conclusion the flare on this passenger side pipe has got to be bad. My feeling is the mold for the flare it was put into was worn causing a slight flaw in the specification to cause a leak when installed. Have you had a problem with these pipes and what are you willing to do about my problem since it appears nothing can be done to re-bend the pipe flare w/o causing irreversible damage.
Thank you
Respectfully Submitted
Your thoughts anyone.....
Unlawfl
Thank you
Unlawfl
RE: Pypes off road H pipe question 05-08Mustang
call john at blue oval industries he will probly be able to help.
http://www.blueovalindustries.com/
