Astra Hammond and GPS Antenna
RE: Astra Hammond and GPS Antenna
ORIGINAL: ink003
i've got the astra hammond louvers and the satelite radio antennae - no problems.
just dont put the antenna under the glass
I'm sorry, I think I used the wrong term. By "rear deck" I meant on the shelf behind the rear seats under the glass. My bad.
Will it still work?
Will it still work?
couldn't tell you. I'd imagine that metal just above it is not good for reception, but maybe it won't be enough to cause any harm
you could always try it with a test fit, and drive around and see if it works
if you do, tell us
if you do, tell us
Now I have to figure out what is more important, louvers or the GPS. I really do not want to mount the antenna under the dash. What a pain...
I read that GPS antennas need a clear view of the satellites.
They don't work when you're in tunnels and mine has problems when driving around tall buildings downtown.
I would expect the rear louvers will block most of the signals.
ORIGINAL: SeanoStang
just reinstall the antenna somewhere else
sheesh!
sheesh!
Sheesh!
