Shebly razors
Shebly razors
I am getting razors this weeks and I would like to see pictures of 18x9 razors. I want to know what backspacing and offset to get. I do not want the wheels to stick out at all but I do like the look when they have that wider more aggressive stance. I saw that all mustangs have a 6 inch backspacing should that remain the same? please help and post pics so I know how the different backspacing looks.
RE: Shebly razors
I ran a misordered set of American Racing in a 18x9 w/40mm offset with a 255/45/18(nittos-555's).The look was excellent and better yet the ride was extreamly smooth.I did order 20's Redlines but there was a miscommunication on the order.
RE: Shebly razors
Weeeellllll, the wider more aggressive stance is the 24mm backspace. The 40mm will provide a more tucked look, which personally I prefer. If you have the new issue of Modified Mustangscheck the cover shot. It's a perfect example of the difference between 24mm and 40mm offsets. Front car is 40mm, rear is 24mm.
RE: Shebly razors
hard to show but the car on the right is 40mm offset, the skunk-striped one is 24mm. A better photo is needed like the mag cover...
http://www.modifiedmustangs.com/issuepreview/
RE: Shebly razors
heres a thread from month or two ago that has some pics for ya
https://mustangforums.com/m_4440449/tm.htm
good luck I will also be getting some razors soon most likely black and will probably go with 24mm offset gives it a meaner/wider stance in my opinion
RE: Shebly razors
40mm = politically correct. You're a true S197 fan, youlike slamming on the gas but you stop at the speed limit, and you put the window down but only if you have your hat and sunglasses on.And... you probably wear underwear and not boxers.
24mm = Meaner, widerstance. You look at your car and say "thats sick" and thats all you care about in the world.
RE: Shebly razors
ORIGINAL: ohnoesaz
RE: Shebly razors
ORIGINAL: ohnoesaz
