Cap off when bleeding brakes/pedal-pump clutch bleed?
The big reason to have the cap on while you're bleeding the brakes is to minimize the exposure of the brake fluid to ambient air. Brake fluid is hygroscopic, so it'll absorb water out of the atmosphere if left exposed to the air. Obviously, this is much worse on a humid day, but typically, water in the brake fluid is one of the main reasons it needs to be bled and/or flushed as often as it does (assuming you don't track the car), so it make sense to minimize the amount that gets absorbed to begin with.
Just my 2 cents...
Just my 2 cents...
Here's a helpful link for ya OP-
http://www.corral.net/tech/maintenance/brakebleed.html
junior04
09-28-2015 10:53 AM
