weird noise when turning slowly
RE: weird noise when turning slowly
ORIGINAL: Boozshey
Yeah, Eibach Pro's here as well... Let me know what you come up with. But mine was making the sound even before the Eibachs...
Not sure how many of you know this (I didn't), but as you turn the wheels, the entire strut/spring assembly rotates as well. In the pics, look at the isolator near the bottom of the spring - notice that it's not in the perch where it should be - is this due to the it "riding" up over time? If so, this gives you metal-to-metal contact which just might be the culprit of the creaking sound. And since Boozshey said he noticed it before he installed the Eibachs, it also could be those wonderful stock strut bearings. If it is the isolator being out of place, I wonder if some sort of adhesive would keep it in place....or maybe a tie wrap at the upper-most end of it to keep it from riding up...just kind of thinking out loud... Also, I'd be interested in seeing pics of some of your (anyone really) strut/spring.
ORIGINAL: brendend
so.... if i put some sort of lubricant there it might stop?
AmericanMuscle4.6GT
11-10-2015 02:06 PM
