Gears...how do I find out what they are?
RE: Gears...how do I find out what they are?
Also FYI, if you have a set of gears out of the car that you are trying to get the number on, all you have to do is count the splines on the shaft, then the splines on the round part, then divide the big number by the little number
Ex.
10 on the shaft
41 on the gear
= 4.10
Ex.
10 on the shaft
41 on the gear
= 4.10
ORIGINAL: rshamekh
No way! I'm pretty sure my car turns 2k at 60 mph, and 3k at 100 mph EXACTLY!!!
ORIGINAL: Steve O Chap
With my 3.31s I'm right around 75mph at 2k rpms...
my 06 auto has 3.31 per the door sticker
prior to 07 the 3.55 was standard on the sticks and 3.31 standard on the auto
after 07 they both got 3.31 but with an option for the stick to upgrade to 3.55
Nice info. That has everything I need to know. Thank you very much.
ORIGINAL: mlcrycc
You can also get it from your door sticker.....
http://www.2005stang.com/gallery/alb...1/vincodes.pdf
BTW, if someone has changed the gears, hopefully they changed the tag on the rear differential. Or at least written the new gear # on it with a grease pen.
ORIGINAL: GT06GT
just note yourspeed at say 2K RPM in 5thand match it to a gear chart. I dont recall the link but if u search for it you can find a chart for 3.55 ratio/4.10 ratio/3.73 ratio and the other stock config.
Hope that helps as an alternate to knowing
that's why I never get why the big deal to make so many cars faster.
How many are getting paid to drive 12 second Mustang?
I guess bragging rights have a high cost.
lincolnshibuya
12-08-2015 04:37 PM
