RAN OVER GUM...NEED HELP!
RE: RAN OVER GUM...NEED HELP!
Replace all effected parts ASAP before the gum spreads and consumes the entire car...
Actually, I would try the freezing method first because it usually works and you don't have to use chemicals on your paint. Goo Gone would be my second choice, I've used it with great results.
Liquid Nitrogen, works every time for me, or just get some dry ice and hold it in your bare hands for a couple minutes, to heat it up, then gently apply it to the surface of the gum, it should harden, and fall right off....
ORIGINAL: Cal26Stang
wow what a bunch of pansy ways to clear it out haha. This is a little bit more time consuming but it will leave a big grin on ur face Change the front tire to the rear. Do a burn out, have a beer do another burn out and then replace the tires again and watch your piece of artwork on the road
Andrew
Andrew
