How do I find out what gears I have?
#21
RE: How do I find out what gears I have?
ORIGINAL: cartel
Dont worry about the other wheel......Just use one wheel, for your refrence
ORIGINAL: 157db
[align=left]1. Jack up bothrear wheelsoff the ground and chock the front tires (for safety). [/align][align=left][/align][align=left]2. Place yourcar in neutral and place a small dot on the aft end of the drive shaft. [/align][align=left][/align][align=left]3. Now place a dot on the tire as well. Have someone turn the tire one revolution while you are under the car watching the dot on the rear of thedrive shaft. Count the number of turns it make and use the chart below to determine the gear ratio you have. [/align][align=left][/align]2-3/4 turns= 2.73:1
3 turns= 3.08:1
3-1/2 turns= 3.55:1
3-3/4 turns = 3.73:1
4 turns = 4.10:1
And let the other tire thats in the air do what?
Rotate at will or what? Explain yourself better.
3 turns= 3.08:1
3-1/2 turns= 3.55:1
4 turns = 4.10:1
quote:
ORIGINAL: 157db
1. Put stang in neutral with the wheels chocked.
2. Jack up one side of the rear end.
3. Mark driveshaft with tape to count revs.
4. Rotate the tire one revolution and count driveshaft revs.
5. Do math.
ORIGINAL: 157db
5. Do math.
#23
ORIGINAL: Daniel60
What is the top speed for the 4:10 gears with the brenspeed tune and a course CAI?
CAI/Tune maybe 161 mph @ 5700 rpm (Drag Limited).
Power Addermaybe 183.5 mph@ 6500rpm (RPM Limited).
That of course assumes you are making enough power to overcome drag at that speed.
musnicki
09-23-2015 07:11 AM
09-03-2015 07:14 PM
