Cams with Bolt ons worth it?
RE: Cams with Bolt ons worth it?
ORIGINAL: jwgroovin
I'm pretty happy with my Comp Stage IIIs.
John
John
2005 Mustang GT
348hp/332trq NA, bolt-ons/cams
12.67 @ 109, looking for 12.00 in 2008
ORIGINAL: ranebowcyxx
270RWHP with my cams, oh yeah it's a 6.
How do you guys think they made power before FI became so cheap? So I got 80 hP to the wheels, it's worth it IMO
ORIGINAL: whtcanbrwnd04u
How much did they cost you installed? Btw... they sound SICK.
ORIGINAL: jwgroovin
John
John
The biggest issue with cams right now is the installation cost. The NSR versions that are coming out now will still set youback with a $500 labor charge, and cams with springs/retainers will easily cost $1000 to install (as mine did). Everyone gave me a hard time given the expense, but I'm well on my way to joining a very short list of folks hovering at or below 12.00 with a NA car. I've been working out a clutch problem, and once that was fixed, started working through tuning the rearsuspension. This NA car bites down hard. Check out this pic and you can see the car twist and nearly raise the driver's front tire off the ground, and the passenger rear tire getting trounced. And that was at 18psi in those tires:
Cams alone don't give you a whole lot out of the box. Just depends what you want out of the car. Find someone that knows how to tune the 4.6 with aftermarket cars and you'll have a handful to play with on the street or track. You CAN get torque: this is last week's carnage on theright rear lower control arm relocation bracket. The car almost stopped dead it bit so hard:
If you got the bucks, the necessary bolt-ons, and someone that knows there way around a custom tune, you will NOT be dissatisfied.
John
ORIGINAL: Fullsayl
Bro those sound freaking fantastic. Did you use the Comp Beehives as well?
John
junior04
09-28-2015 10:53 AM
treesloth
09-28-2015 07:03 AM
