anyone use clr to clean rims?
my buddy said i should use clr to try to get the crap off my rims. he says it wont hurt the finish and well more then likly get the gunk off. has anyone used this or know a reason i shouldnt use it?
RE: anyone use clr to clean rims?
I don't know if it hurts the finish much but I have used it on the pad and rims before and it seemed fine to me. I've even used it inside my muffler to get that black out a bit
I've mistakenly found out that brakleen (Brake Parts Cleaner), cleans my rims real good. I was spraying my rotors one day, and was cleaning the excess that was dripping on my rims. It took some of road tar off easily.....But, on CRC web site, it says that its not safe for plastic. But the CRC Carb Cleaner is safe for plastics....
^Plastic Safe=No^Plastic Safe=Yes
The CLR website specifically states "DO NOT use this on your car".
See link:
http://www.jelmar.com/CLRbasic.htm
See link:
Only use pH neutral cleaners on vehicle finishes and rims.
CLR is not pH neutral.
CLR is for the removal of Calcium, Lime and Rust.
Are these substances on your rims and they need
to be removed? If so, how did these mineral deposits
get on your rims?
get on your rims?
CLR is Hydrochloric Acid. I wouldn't put it anywherenear aluminum or stainless steel, it will dissolve both. It may not attach paint that quickly but I wouldn't chance it. I use Simple Green diluted half strength with water to clean my rims and tires. Cuts the brake dust with no corrosion to the wheels or brake components.
