just bought Pypes Mid-Muffler system used from a MFer!!
RE: just bought Pypes Mid-Muffler system used from a MFer!!
If you save the picture and look at the properties (right click > properties > summary > advanced) in Windows XP, the date says 4/24/2008 at 1:01 PM.
i did notice that about the drivers side axle back pipe.. has like a wierd bend in it.. i dunno.. we will see when it gets here..
he already shipped them out to me so should be here by wednesday.. cant freakin wait.. i hate the suspense between buying the mod and waiting at the front door for the brown box guy to drop it off!
ORIGINAL: GTstangB.F.D.M.
If you plan to install them yourself, get a block of wood and hammer to you can bang the over axle pipe into the back of the mufflers. you'll not be able to get them all the way in otherwise.
I'd go ahead and hang the over axle pipes with the tips and then start with the bent pipe from the X-pipe back. I just removed mine to do the clutch and that's how I put them back in. Pull the x-pipe clamp back some along with the short bent pipe from the pypes kit, then tighten the x pipe clamp so it won't move. Put your mufflers on and bang them in with the wood and hammer once they are situated and then do the same with the over axle pipe into the back of the mufflers. Then loosen the x-pipe clamp and slide the whole thing forward and retighten.
Does your x-pipe use the stock sliding clamp? If not then the above instructions may not work.
09-10-2015 08:39 PM
