Sponsored by:
Sponsored by:
M/T ET Streets
Old 05-01-2008, 09:58 AM
MUSTANGEXPERT
MUSTANGEXPERT's Avatar
Default M/T ET Streets
I have read that alot of you are using the m/t et street 26x11.5x17 i would like to know how much you like them and if you had any problem with your tranny or your rear of the vehicle. Most of you are getting good 60 times. I just want to know if its worth it and if i am going to have any problems with my rear???
MUSTANGEXPERT is offline
Old 05-01-2008, 10:13 AM
zkiller
zkiller's Avatar
Default RE: M/T ET Streets
well I know 179.00 a piece is worth 1.60 time for me at the track.
I even run them on the street occasionally.
zkiller is offline
Old 05-01-2008, 10:18 AM
MUSTANGEXPERT
what have you been doing in the quarter mile and have u had any kind of problems with your rear??
Old 05-01-2008, 10:40 AM
MUSTANGEXPERT
bump
Old 05-01-2008, 10:45 AM
06VistaBlueGT
06VistaBlueGT's Avatar
I ran the ET Street Radials last year, my best 60ft was 1.84 but that is due to limited mods. I have had no tranny or rear end issues. This year I'm running M&H racemasters. They are narrower than the Mickey's but are just as sticky. I am doing 5k rpm clutch dumps. This yearI also have an Aluminum DS and 4.10 gears. My best 60ft is 1.76. My best 1/4mile is 13.07 but I'm not going for best time I'm going for most consistency since I bracket race.
06VistaBlueGT is offline
Old 05-01-2008, 11:02 AM
zkiller
zkiller's Avatar
My car runs ETs from 11.0 11.4 and what kind of rear problems would you mean?
The 8.8 is pretty stout differential. No I have never had any problems in over two years of drag racing the car.
zkiller is offline
Old 05-01-2008, 11:20 AM
forensicsteve
forensicsteve's Avatar
Used MT ET streets on 15 inch rim until very recently (switched to 29.5 tall Hoosier true slick). The MTs are very very good. I have a 9 inch built rearend but still worry about something breaking back there (using a transbrake is very hard on a transmission and rearend).A buddy used a set of MT 275/40/17a couple of weeks back. He has a builtmotor but everything else is stockand is pushing 520 rear wheel torque. On his third pass at the track, we all got to witness his rearend pop. He had to leave his car at the track, pick up my trailer and head back to the track. He has since ordered a 9 inch.
I thinkwe wereusing the street tune at 11lbs boost producing 520/530 rear wheel with the MT ET streets and car ran maybe 11.2 (???) at that time, with 1.6 sixty ft times.
Video of track burnout on the MT ET streets
http://s149.photobucket.com/albums/s76/forensicsteve/?action=view¤t=burnout.flv
forensicsteve is offline
Old 05-01-2008, 06:08 PM
MUSTANGEXPERT
BUMP
Old 05-01-2008, 06:32 PM
whtcanbrwnd04u
whtcanbrwnd04u's Avatar
I did 5500 rpm dumps, and no problems. Im getting 2.0 60fts, but i blame those on my 3.31's
whtcanbrwnd04u is offline
Old 05-01-2008, 07:23 PM
Stkjock
Retired Mod
Stkjock's Avatar
i would think if your going to drag the car a lot you should upgrade to rear diff to a trutrak
my stock rear started to make noise (clutch packs) after abut 22 passes at the track
Stkjock is offline
mungodrums
09-28-2015 10:54 PM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
09-16-2015 07:53 PM
Quick Reply: M/T ET Streets
