Clicking noise in front suspension
I'm not sure if this is what everybody posts about, but according to the rest of the threads I've read it's different because others only experience it when they hit a bump.
Anyways, I've had this noise on the passenger side of my car long time ago and it went away on its own before I've had any suspension mods done. Now recently I've been noticing the same sound coming from the drivers side front wheel this time. Today it got really loud. It occurs when I take a sharp turn whether the road is perfect or it has bumps on it no matter which way you're turning and at 60 mph you hear 2-3 clicks per second. The sound reminds me of a clock that's a lot louder than a normal one. Also reminds me of the time when one of the balance weights on the wheel camelose and was rubbing onto the caliper. Now here's a crazy part-- when I'm pulling into my parking space and the wheels are turned all the way to the left I also hear it even going at 1-2 mph, maybe 1 click per second and it's not as loud as it is at high speeds. I lifted up the car today, turned the wheels all the way and spun the tire with it being up in the air but it sounded normal so in other words, there's gotta be pressure on it for the sound to occur. I got Steeda strut mount so those are out of the way. Could it be the wheel bearing... at 1mph??? Steering problem? It's really annoying and even knowing that it won't make my wheels fall off I rather get it fixed than "enjoy" hearing it even with my stereo volume half way up (that's how I heard it today so yeah it's loud). Another thing, I don't hear it with the windows up.
RE: Clicking noise in front suspension
Jack her up and rotate the tire by hand?
Then remove the tire assembly and rotate the hub by hand?
Then roll the tire/wheel assembly around by hand and listen for the clicking.
It could be the tire guys watch inside the tire/rim assembly?
Timex, keeps a licking and is still ticking??
Something inside the tire. Loose TPMS sensor, maybe.
The lug nuts should be at 98 Ft Lbs each. TIGHT.
lug nuts tight? i had clicking like that once,my lugs where loose and it made a noise only when pulling up to a stop light at low speeds,it was the wheels shifting.i doubt this is your problem but you never know.
Got a little updage. It finally pissed me off to the point where I decided to check torque on ALL the suspension bolts including the mentioned above sway bar end link ones. Everything was the way it's supposed to be for the exception of the upper part of the driver's side sway bar end link nut. It made 3/4 of a turn before itgot to where it's supposed to be at and that caused all that noise.It's funny how with the stock sway bar I had the same noise coming from the opposite side-- tells me the end link came a bit lose from the factory. Thanks to those who tried to help and special thanks to AZAlloy
