Looking to fill up the wheel gap
I need some help in what to do to fill in the wheel gap without lowering it. I don't want to lower the car because I already scrape in some places and I know it will only get worse if it's lowered. Any help would be greatly appreciated.
RE: Looking to fill up the wheel gap
Easy, couple of members here who is running 20's with 40-45 sidewall....fills them out nicely. You will have a little less power of the line, but that can be corrected with 4.10:1 gears. With the 20's, your side wall will actually be less than you have now, assuming you are running 55's now?
Then use this to re-adjust your computor to the correct speed reading.
http://www.1010tires.com/TireSizeCalculator.asp
You'll need a tire that's 2" taller to fill-up 1" of wheel gap. That's a 29" or so.
in 20", that's about a 255/45, 265/45, 285/40, 295/40
in 18", that's about a 255/55, 275/50, 285/50, 315/45
