help!! one foglight brighter then other after eleanor grille conversion
I bought and installed the street scene grille on my 06 and the drivers side is alot brighter then my passenger side. Any ideas? At first i thought it was an adjustment but after looking at it it is definately alot brighter. i used the extensions that came with the grille. please help!!! I am getting people flashing theyre high beams at me!!
RE: help!! one foglight brighter then other after eleanor grille conversion
I hope that does'nt happen to me. I just ordered a grille from Blue Oval industries. By the way, I see you are running 4.30 gears also. [8D]
I know it sounds crazy, but that may be the bulb about to go out... Had this happen once with a set of Fogs, on my Wrangler though, dunno...
I don't know the set up on the fog lights but on the older cars sometimes a dimmer light was because of a loose ground wire. Did they have seperate ground wires that bolted to the car by any chance if so check them.
Did you use a different set of bulbs? My buddy bought some Sylvania silver star bulbs and it looked like a giant cyclops eye. He put the stock bulbs in and everything was fine.
Sounds like the bulb is either about to go out or one of them is having a connection problem. I'm putting my money on the bulb about to crap out. I'd use this as an excuse to upgrade to some Silverstars or HIDs.
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
