Sponsored by:
Sponsored by:
Steeda lowering springs with stock shocks
Old 05-09-2008, 12:20 PM
acascianelli
acascianelli's Avatar
Default Steeda lowering springs with stock shocks
If I want to run a set of Steeda lowering springs, is it OK to continue using the stock shocks and struts?
acascianelli is offline
Old 05-09-2008, 12:21 PM
Tracedaddy
Tracedaddy's Avatar
Default RE: Steeda lowering springs with stock shocks
Short answer. Yes. It's fine.
Tracedaddy is offline
Old 05-09-2008, 02:18 PM
okbfd
okbfd's Avatar
Yep, I've got the Eibach pros with the rear lowered 1.5" and it works fine with the rest stock
okbfd is offline
Old 05-09-2008, 03:37 PM
157dB
Cut & Paste Expert
157dB's Avatar
Yep, they will just wear out faster.
The internal valving is now lower than
OEM ride height so there is some trade
off for using OEM shocks at non-OEM
ride height.
157dB is offline
Old 05-09-2008, 03:39 PM
Tracedaddy
Tracedaddy's Avatar
So when/if they OEM wears out, replace them then.
Old 05-09-2008, 03:41 PM
ThumperMX113
ThumperMX113's Avatar
Yes but honestly it doesn't ride that great. I've got the Steeda Ultralites on my girl's car with stock shocks/struts. The Ultralites are supposed to be a pretty good riding sping too. I just recently added Steeda Sport Springs and Tokico D-Specs shocks/struts and the difference is night and day. I'd say wait until you can afford both since you'll need to tear it all apart anyways. Save yourself some headache and time. I PROMISE you won't be unhappy.
ThumperMX113 is offline
Old 05-10-2008, 04:20 AM
FINGT
FINGT's Avatar
ORIGINAL: ThumperMX113
Would you be more specific.
How does the Ultralites with stock shocks compare to Steeda Sport springs with Tokicos ?
Do you have now better ride comfort with the Tokicos ?
Ingterested to know as I'm running Sport springs with stock shocks.
[/align]
FINGT is offline
Old 05-10-2008, 04:58 AM
dynamicmustangt
dynamicmustangt's Avatar
I also say wait to buy them both or save up and buy the Ford Racing supension kit.
dynamicmustangt is offline
Old 05-10-2008, 09:04 AM
vf96
vf96's Avatar
I'm running UltraLites & ProAction Shocks & Struts. save a few bucks do the install of both at the same time. It's a lot of work......compressing the front springs..& i'm pretty sure you may need a front end alignment even if you put your stock struts back in. It's a MUST if you do both at the same time.
vf96 is offline
Old 05-12-2008, 02:50 PM
acascianelli
Thanks everyone, I got the answers I was looking for. Looks like if I'm going to do this I'll have to save up to do it properly first.
2007CalSpec
12-13-2020 11:42 AM
Pyrate Dave
09-10-2015 07:30 PM
RWHEELS
09-05-2015 03:42 PM
Luke9222
09-04-2015 06:46 AM
09-02-2015 08:40 PM
Quick Reply: Steeda lowering springs with stock shocks
