Royal purple synchromax in manual transmission...are you running it?...
I had read somewhere how the temperature of the transmission is greatly reduced when running the royal purple synchromax. I had no idea the difference was night and day though.
Before changing the transmission fluid my hurst stick would get really hot. Not so hot that you couldn't hold it for more than a few seconds, but hot enough that holding on to it was uncomfortable.
Now it doesn't get hot at all and I mean nothing. I'm amazed at how cooler it is, but I wonder if the trans was designed to operate at a certain temperature. Generally speaking cooler temps mean longer life. It must be reducing friction of moving parts in order to reduce the temp.
A show of hands who has switched to royal purple synchromax.
RE: Royal purple synchromax in manual transmission...are you running it?...
How hard was it to switch out??? I know the tranny doesnt just have a drain plug like my oil pan. I would definitely switch it out if its something simple to do. (plus it would bring a ton of peace of mind to get the stock fluid out of there)
Damn there has to be more people that have done this!
Moose i agree that it keeps the tranny cooler. Now i dont know if this is a harmful thing at all though. My hurst got a little warm before like you said but does seem to be cooler with the new fluid.
I did notice decreased sound and smoother shifting though so that is a huge plus IMO.
I just swapped mine out for Amsoil. It's hard to tell if it's cooler or not because our cars have remote shifters, so the tranny temp won't really change the temp of the shifter in your hand too much. It does feel a bitsmoother and def a bit quieter.
Yep, RP Synchromax made a big difference in my trans. I didn't notice it that much at first but over the next several days, shifting got smoother and smoother over time. The heat that used to radiate up from my parking brake handle area is MUCH reduced as well.
I've heard a few folks opinions about it not being compatible with some of the internal parts in the trans. RP says its ok and it seems to work well. Enough for me...
ORIGINAL: RedRider0151
You have a drain plug on the bottom of the trans and a fill on the passenger side near the top. I removed the upper fill plug and then removed the bottom. Something to remember though is that ATF is VERY thin fluid. I placed my car on jackstands about 2 feet off the groud and used an oil reservoir contaner that was about 2' round. When I removed that bottom plug the ATF came out like WATER! Hit my reservoir, splashed all over me, my garage floor and everything else in range. [:@]. I'd remove that bottom plug s-l-o-w-l-y.
mungodrums
Suspension
09-07-2015 07:22 PM
09-02-2015 08:40 PM
