Front end Thunk?!?!?!?!? Search used
I am getting some sort of THUNK sound from the front Drivers side. Every time I go over a bump I get a very LOUD thunk. Sounds like something is DEFINATELY loose, however there has been no ill effects onperformance. If it didnt make the sound, I wouldnt think anything was wrong.
I know that people have issues with their strut mounts popping when they lower their stang, but I replaced mine with the Steeda Strut Mounts.
My suspension setup is as follows:
Steeda Sport Springs
Tokico Dspecs
Steeda Adjustable Panhard Bar
HD Panhard Brace
Has anyone encountered a problem like this? Its only the drivers side that makes this noise. What could it be????? I did not install the parts myself, could it be that somethingcame loose? It sounds like it could be the strut mounts.
I amready to set the car on fire. [:@]
Tokico Dspecs
HD Panhard Brace
RE: Front end Thunk?!?!?!?!? Search used
Vinny, I told you when I had that problem that I found out I snapped a locking tab on a bolt that connected the strut to the spindle so there was enough play to make the thunk. jack the car up and pull the wheels see if there is any play or movement there. If there is check the bolts and tighten them.
Therer was a TSB on the mounts as u probably know,,,I have alot of suspension work myself..( SIG) And was able to convince the dealer to replace my mounts and my clunking went away..My mounts are stock...told him my mounts had nothing to do with my Mods,,and he agreed...I would start there..I have heard of same prob with Steeda mounts..but who know..
Good luck..keep us posted but it sounds like the Strut mount prob..
ORIGINAL: PiggySmallz
ORIGINAL: VerginaStang
Which bolts am I checking? It sounds like the car is going to fall apart. How did you snap the locking tab? I've had the stuff installed for a month, and now all of a sudden, its loose, or I broke something?
My upper strut mount nuts were lose on both of my struts and I tightened them down and the noise I was getting went away, but as others have said the sway bar links can cause a clunkingnoise as well if either of those nuts are loose...
What do you guys recommend I tighten the nuts/bolts/screws down with??? I do not have access to a torque wrench.... just muscle. lol
I have to get this taken care of ASAP.
I had the same issue with my stock suspension. After installing dspecs with roush springs, strut and a arm brace I no longer have the thunking noise. The only time I have replicated the sound is when my front sway bar is disconnected. It is a annoying problem. I know this isnt much help, but good luck.
