Customized headlight - no more lense!
#22
RE: Customized headlight - no more lense!
Is this what you were going for?
No lens but I still think you need a lens to cover the actual light or it will get broken. It's there for a reason you know. But good luck anyway
#23
Great lookingMod! I'm going to do this one myself. .....Until I saw this post, I never noticed that it was the Headlight Cover that was making the front end look "weak."....technology strikes again!!!!
What will you do if a rock breaks a headlight? C'MON people.....you will get a new headlight!
What will you do if your passenger side air-bag goes off? I would dump her, and find a prettier date.
+ 3 Cool mod.
+ 3 Cool mod.
#24
ORIGINAL: musicheadt
+ 3 Cool mod.
+ 3 Cool mod.
#29
on my 2005(newer might be different). There was nothing over the reflector. When you pull the lens off the bucket (the louvered pice in the pic) comes out and then you would paint that.
06driver You should have something over the reflector area, If you don't already. Not so much that a rock will hit it but that bulb should be in a weather tight encloseure IMO. those bulbs where not ment to be in the weather I would hate to see you replace the headlight wire harness plug because it got water and dirt in there and corroded
