Anyone running this "Big Daddy" no tune intake..26 HP!
#22
RE: Anyone running this "Big Daddy" no tune intake..26 HP!
I am partial to the AEM. But, I liked the Roush and SLP intake also. But, what is the best. HONESTLY!
[IMG]local://upfiles/90468/BE0848B7F10248D4B14CABAB682FC9CF.jpg[/IMG]
#25
ORIGINAL: 1morepart
sounds crazy.....imo, i would go with a cai and tune
look at this big daddy on gt500
http://ca.youtube.com/watch?v=oVyq3S...eature=related
#26
ORIGINAL: StickShifty
no way, BS. when you install a C&L/tune or a JLT/tune (best of the best intakes) most of the power is from the tune.
#27
yes i certainly wouldnt run this on a tune that was made for the stock airbox! Many details but in short you could really damage your car in this situation i think.
#28
ORIGINAL: howarmat
sorry, no believe that though. Marketing at its best maybe but i wouldnt put that on my car
I would say, just get a CAI/tune combo, from a popular company: JLT, C&L, Steeda, etc, and a comparable tune. I look at it this way, keep it conventional, keep the stock MAF, and go with a tune/ CAI, and if need be, you can just flash back to stock and put your stock airtube/ airbox in in no time! With the tune, its a good foundation to build on, should you do other mods, and a handheld tuner is easier to work with. ( For example, changing out gears, CMCV deletes, LT headers, etc) And if you have an auto, like I do, the tune works wonders with the trans, its well worth it! I would not go any other way! Tried and true method.
#29
ORIGINAL: Legion5
Again this CAI modfies the MAF opening so it reads the wrong air fuel ratio. This means you can never use this CAI with a tune so you're stuck on the mods you can do. Also for it's price, you can get a K&N drop in filter and a tuner, and have the exact same amount of HP, but also have a free tuner.
Now, to those nay-sayers who don't understand how this intake works,I suggest you look into the MAF's that they use on the 5.0's before you go calling this a warmed over K&N that will pop your motor. The design concept Wayne uses is exactly the same as they use on them. Because there is no MAF transfer function in the 5.0's software (which is the table that the computer uses to look up how much air is flowing at what voltage) , it instead relies on a proportional size between the injectors, MAF size and Sensor sampling tube to figure out airflow. My changing the size of one, you have to reclibrate the others (or at least the size of the sampling tube) to keep your readings correct.
There are dozens and dozens of cars that handle things this way. Another of the more popular ones that does it are the Mk III Supra guys with the 7M-GTE's. A popular upgrade is to a Lexus AFM (which is anaologous to our MAF's) and a set of 440cc/min (or 44 lb) injectors. By oversizing the AFM by 25% and the Injectors by 25%, the AFR's will remain the same.
When it says "Non-tuneable" All it means is that there is no update to the MAF transfer needed. You can still tune your little heart out, so long as you leave the MAF transfer alone. The only thing that may add a small level of difficulty is anything that would require an injector swap. Things may get a little hairy there, but I still think any tuner worth his laptop would be able to get it figured out with out much trouble.
#30
This CAI is simply a C&L Racer CAI with anew MAF. That's how he gets away without a tune. He replaces the MAF.
Check out this pictures from this article: http://www.mustang50magazine.com/tec...ake/index.html
I wonder if he sells just the MAF for those that already have the C&L Racer CAI?
Martin
Martin
