MSD Ford Launch Master (two step)
RE: MSD Ford Launch Master (two step)
ORIGINAL: Green08BulliTT
youcan build boost in a car with out load. you have to mess with the timing but it can be done. alot of 2steps alow a timing adjust while your in the locked rpm. its not great for turbo life since it makes alot more heat and added stress.
On very advanced turbo set ups, there can sometimes be another throttle body type plate in between the turbo and the intake manifold. This remains mostly closed under throttle at the line while the driver gives it fuel, causing the turbo to spool putting pressure against the plate. When the driver leaves theline the plate moves and the pressure built up behind the turbo is released and goes forward.
Another is injecting raw fuel into the exhaust upstream of the turbo. Done properly the fuel travels down stream alittle and ignites causing a rapid spooling of the turbo. Again, these are extreme set ups.
Simon -I think I have a good vid to show that very thing you are describing on a 1400 HP supra (I know but refrain from insults bro loves them[&:])
EDIT: here ya go if that is not it- it is very impressive to say the least
http://www.youtube.com/watch?v=4UQseSBJpbM
ORIGINAL: mygt500
Simon -I think I have a good vid to show that very thing you are describing on a 1400 HP supra (I know but refrain from insults[&:])
I'm waiting for someone to get one and bring back a report of their experience.
Maybe we could get MSD to give a few out to the board as test mules. Then when everyone loved them they would make a killing. Unles they broke motors like others said and that wouldn't be good for MSD.
I won't be needing it for a while, but it sure is interesting.
I saw a few more examples in there. One of them looked like they were dumping fuel through the exhaust like I spoke about earlier.
That car is damn fast. Very good working suspension.
Here is a 1900 HP Viper twin turbo....sounds like a rocket explosion which I assume that is what you were getting at from the post above!
http://www.youtube.com/watch?v=yBEeo6l3a6s
My car is a bracket racer and most other bracket racers it seemshave botha 2 step and delay box. We installed the 2 step about a month ago (delay box on order). The attached vid shows the car at the line against a gutted non-street legal drag car. You can really hear his 2 step working for him (can't hear the mustang's at all). In conjunction with the transbrake works great.
http://s149.photobucket.com/albums/s76/forensicsteve/?action=view¤t=10-6a.flv
I had considered a 2 step as well. If you bracket race you have to be careful of what class you run. At the track I run you can't have any kind of launch assist and run a street class. If they find out you're running launch assist, they will move you up to the super pro class. Now another track I run at they could care less.
