550 RWHP
550 RWHP
I have a 2006 GT with an auto transmission, and I want to make 550 RWHP with the stock block in place. I'm going to go with a S/C (most likely a KB) and that most likely means forged internals. Besides the other necessary upgrades I need to make (tranny upgrades, suspension, brakes, etc.) is there anything else I would need?
RE: 550 RWHP
I'm not too sure if the parts are included with the sc kit you're looking at, if so you're fine, if not, I believe you will need bigger injectors and another fuel pump, I'm sure the sc guys will chime in soon though
RE: 550 RWHP
ORIGINAL: MustangBatman1
RE: 550 RWHP
ORIGINAL: *DarkStar
...Like the KB Boost a Pump....I'm a retard
RE: 550 RWHP
That increases the output of your stock pump, I know that works fine with normal sc installs but I'm not sure if it supports the amount of power you're going for.
ORIGINAL: *DarkStar
RE: 550 RWHP
get the GT500 duel pumps and replacement module from any of our sponsors! that will cover your fuel system needs! The whipple comes with it but the KB is just a boost-a-pump (I think). Lethal Performance (boost addict) also has a crazy wicked triple pump system that includes everything from hat to motor (fuel rails etc) that supports up to 1000 HP! (but 1899 dollars) Others like the Ford GT duel pumps and some add a BAP or 2 to that! For your application I would go with the GT500 pumps...its a complete kit and you can get it for 700 dollars or so....
