TPMS - where do I have them transferred?
I just called a few tire shops and they all said they can't transfer the sensors. Where do I have this done? Please dont tell me I have to take it to the dealership. (I know I have to buy the straps.)
RE: TPMS - where do I have them transferred?
those tire shops are stupid
You just need a flat screwdriver and the straps.
Take the tire out, with the screwdriver break the the stock strap (by turning the retainer 90 degrees).
Remove the old strap, remove the sensor from the strap, you don't need to remove the sensor from the craddle.
Slide the new strap in.
Trim the new strap at size.
Set the sensor in the opposite side of the pressure valve at the valley the closest possible to the outer face of the rim.
You are ready to go.
I did it myself at the tire shop.
There is a place on the net that has the service manuals of this cars, there is a chapter on the TPMS change.
Every place I called does it when Icalled around to havemine done. Ended up cheapest AT the dealership, including balancing.
You can buy a banding toolat most hardware stores or off a tool truck,I was just wondering if a large zip tie would work? all they do is hold it to the wheel. I have some extra sensors so the nexst time I have a chance I will try it. The banding tool I have for c/v boots works.
